Schwarzbeck UHALP 9107
The Schwarzbeck UHALP 9107 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck UHALP 9107:
The frequency range of the Schwarzbeck UHALP 9107 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck UHALP 9107.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck UHALP 9107 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck UHALP 9107
- Google image search: Schwarzbeck UHALP 9107
