Schwarzbeck UHA 9105
The Schwarzbeck UHA 9105 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck UHA 9105:
The frequency range of the Schwarzbeck UHA 9105 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck UHA 9105.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck UHA 9105 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
