Schwarzbeck UHA 9125D
The Schwarzbeck UHA 9125D device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck UHA 9125D:
The frequency range of the Schwarzbeck UHA 9125D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck UHA 9125D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck UHA 9125D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck UHA 9125D
- Google image search: Schwarzbeck UHA 9125D
