Schwarzbeck USLP 9142
The Schwarzbeck USLP 9142 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck USLP 9142:
The frequency range of the Schwarzbeck USLP 9142 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck USLP 9142.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck USLP 9142 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck USLP 9142
- Google image search: Schwarzbeck USLP 9142
