Schwarzbeck VAMP 9242
The Schwarzbeck VAMP 9242 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VAMP 9242:
The frequency range of the Schwarzbeck VAMP 9242 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck VAMP 9242.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck VAMP 9242 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
