Schwarzbeck VHA 9103B
The Schwarzbeck VHA 9103B device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VHA 9103B:
The frequency range of the Schwarzbeck VHA 9103B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck VHA 9103B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck VHA 9103B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck VHA 9103B
- Google image search: Schwarzbeck VHA 9103B
