Schwarzbeck VULB 9160
The Schwarzbeck VULB 9160 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VULB 9160:
The frequency range of the Schwarzbeck VULB 9160 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck VULB 9160.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck VULB 9160 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck VULB 9160
- Google image search: Schwarzbeck VULB 9160
