Schwarzbeck VULB 9163
The Schwarzbeck VULB 9163 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VULB 9163:
The frequency range of the Schwarzbeck VULB 9163 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck VULB 9163.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck VULB 9163 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
