Schwarzbeck VULB 9164
The Schwarzbeck VULB 9164 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VULB 9164:
The frequency range of the Schwarzbeck VULB 9164 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Schwarzbeck VULB 9164.
Be careful changing these setting as RadiMation® is no longer able to verify if the Schwarzbeck VULB 9164 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Schwarzbeck VULB 9164
- Google image search: Schwarzbeck VULB 9164
