Schwarzbeck VULP 9118B
The Schwarzbeck VULP 9118B device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VULP 9118B:
The frequency range of the Schwarzbeck VULP 9118B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck VULP 9118B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck VULP 9118B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck VULP 9118B
- Google image search: Schwarzbeck VULP 9118B
