Schwarzbeck VULP 9118C
The Schwarzbeck VULP 9118C device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VULP 9118C:
The frequency range of the Schwarzbeck VULP 9118C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck VULP 9118C.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck VULP 9118C is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck VULP 9118C
- Google image search: Schwarzbeck VULP 9118C
