Schwarzbeck VUSLP 9111
The Schwarzbeck VUSLP 9111 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Schwarzbeck VUSLP 9111:
The frequency range of the Schwarzbeck VUSLP 9111 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Schwarzbeck VUSLP 9111.
Be careful changing these settings as RadiMation® is no longer able to verify if the Schwarzbeck VUSLP 9111 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Schwarzbeck VUSLP 9111
- Google image search: Schwarzbeck VUSLP 9111
