Shutdown.AskSureToClose.WithOpenDocuments
This advanced option determines if a question should be raised when RadiMation is closed, and one or more documents are still open. The question will ask the end-user, if he is sure to close RadiMation. He will then have the possibility to not close RadiMation, if he for example pressed the top-right 'x' by accident.
The default value of this advanced option is set to True.
This advanced option does not have an influence on the question that is raised when RadiMation is closed when no documents are open. See the Shutdown.AskSureToClose option for that.
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
