Siglent Technologies SSG3021X-IQE
The Siglent Technologies SSG3021X-IQE device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Siglent Technologies SSG3021X-IQE:
The frequency range of the Siglent Technologies SSG3021X-IQE as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Siglent Technologies SSG3021X-IQE.
Be careful changing these settings as RadiMation® is no longer able to verify if the Siglent Technologies SSG3021X-IQE is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Siglent Technologies SSG3021X-IQE
- Google image search: Siglent Technologies SSG3021X-IQE
