Siglent Technologies SSG6083A
The Siglent Technologies SSG6083A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Siglent Technologies SSG6083A:
The frequency range of the Siglent Technologies SSG6083A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Siglent Technologies SSG6083A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Siglent Technologies SSG6083A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Siglent Technologies SSG6083A
- Google image search: Siglent Technologies SSG6083A
