Singer CLS-105A
The Singer CLS-105A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Singer CLS-105A:
The frequency range of the Singer CLS-105A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Singer CLS-105A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Singer CLS-105A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
