Single DLL Upgrade
How do I install a single or a set of DLL's that I have received from the RadiMation® support team or reseller?
Procedure
- If you received a ZIP file, please unzip the ZIP file first.
- Close all instances of the RadiMation® program and ensure that it is not running in the background anymore.
- Use Microsoft MS Windows Explorer to browse to the directory in which your version of RadiMation is installed. (This is depending on e.g. the installed language of the Windows operating system. For example: C:\Program Files\Raditeq\Radimation\Version x.y.z or C:\Program Files (x86)\Raditeq\RadiMation\Version x.y.z) (Tip: If you use a shortcut of your RadiMation® version: click the right mouse button at the shortcut and choose from the context menu 'Open file location'.)
- Make a backup / copy of the DLL file(s) that you are going to replace.
- Copy the file(s) into the folder.
- If a DEVICES.DAT file is also included in the ZIP file, it also has to be copied to the same directory.
- Start RadiMation® again.
The .DLL set is now updated, and this specific version of RadiMation® will now directly use the updated DLL file(s).
