Stanford Research SG 384
The Stanford Research SG 384 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Stanford Research SG 384:
The frequency range of the Stanford Research SG 384 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Stanford Research SG 384.
Be careful changing these settings as RadiMation® is no longer able to verify if the Stanford Research SG 384 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
