Steatite QSH-SL-260-400
The Steatite QSH-SL-260-400 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Steatite QSH-SL-260-400:
The frequency range of the Steatite QSH-SL-260-400 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Steatite QSH-SL-260-400.
Be careful changing these settings as RadiMation® is no longer able to verify if the Steatite QSH-SL-260-400 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
