Stripline (KRE2720)
The Stripline (KRE2720) device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Stripline (KRE2720):
The frequency range of the Stripline (KRE2720) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Stripline (KRE2720).
Be careful changing these setting as RadiMation® is no longer able to verify if the Stripline (KRE2720) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Stripline (KRE2720)
- Google image search: Stripline (KRE2720)
