Sunol Sciences JB1
The Sunol Sciences JB1 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Sunol Sciences JB1:
The frequency range of the Sunol Sciences JB1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Sunol Sciences JB1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Sunol Sciences JB1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Sunol Sciences JB1
- Google image search: Sunol Sciences JB1
