TDK HLP-3003C
The TDK HLP-3003C device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TDK HLP-3003C:
The frequency range of the TDK HLP-3003C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the TDK HLP-3003C.
Be careful changing these settings as RadiMation® is no longer able to verify if the TDK HLP-3003C is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
