TESEQ CAL U100B
The TESEQ CAL U100B device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TESEQ CAL U100B:
The frequency range of the TESEQ CAL U100B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the TESEQ CAL U100B.
Be careful changing these settings as RadiMation® is no longer able to verify if the TESEQ CAL U100B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: TESEQ CAL U100B
- Google image search: TESEQ CAL U100B
