TESEQ CDN A301
The TESEQ CDN A301 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TESEQ CDN A301:
The frequency range of the TESEQ CDN A301 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the TESEQ CDN A301.
Be careful changing these settings as RadiMation® is no longer able to verify if the TESEQ CDN A301 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: TESEQ CDN A301
- Google image search: TESEQ CDN A301
