TESEQ CVP 2200A
The TESEQ CVP 2200A device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TESEQ CVP 2200A:
The frequency range of the TESEQ CVP 2200A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the TESEQ CVP 2200A.
Be careful changing these setting as RadiMation® is no longer able to verify if the TESEQ CVP 2200A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: TESEQ CVP 2200A
- Google image search: TESEQ CVP 2200A
