Tabor Electronics WW5061
The Tabor Electronics WW5061 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tabor Electronics WW5061:
The frequency range of the Tabor Electronics WW5061 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Tabor Electronics WW5061.
Be careful changing these settings as RadiMation® is no longer able to verify if the Tabor Electronics WW5061 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Tabor Electronics WW5061
- Google image search: Tabor Electronics WW5061
