Talk:RadiMation Application Note 108
The general purpose of this application note is to provide techniques how the calculations in RadiMation can be validated. The general rule for this is: RadiMation provides graphs where you can see the measured data. Using export to excel the data can be made available in excel, where own calculations can be performed to determine the value.
It probably is best to create the application note where we first create a general explanation that RadiMation provides a lot of graphs, which can be copied to excel to compare and perform calculations. In the rest of the application note we can give the two examples that are described below.
1) An example would be to export the forward power and average field of a calibration to excel.
Then the forward power for an ideal field of 10 V/m can be calculated. Then the results of a real substitution test with that same calibration file, can be used to export the forward power again to excel to compare it with the manually calculated forward power. The differences between the excel calculated and the really applied forward power should be very small, which proves that the calculation in RadiMation is correct. For a further optimized calculation, also the 'calculated field' from the substitution test can be used to correct the really applied forward power, which will result in an even smaller difference between the excel calculated and the really applied forward power.
2) Another example is how to verify the modulation conservation:
Perform a test with modulation, and then perform a test with modulation and conservation. Depending on the modulation depth, the difference in the signal power as it is shown in the graphs can be used to determine if the correct step is performed. This can again be done by exporting the graphs to excel and comparing them.
Joro (talk) 10:15, 29 January 2019 (CET)
