Talk:RadiMation Application Note 118
When purchasing RadiMation, you are required to fill in a RadiMation installation guide. You can already install RadiMation without a license key. While using RadiMation without license key, you will use RadiMation as free mode. In RadiMation free mode, you can check all available drivers. From the configuration menu -> Configuration -> Device drivers [image]
You may also find the supported device list here: [Equipment List]
If the device is currently not supported, the driver needs to be created.
For creating a device driver, RadiMation support team is required to have a "Programming Manual" of the equipment.
Most of the time, this manual comes with the equipment. In other cases, you can request this manual at your manufacturer.
This is also one of the (not only) reasons that the newly added device must still be supported by the manufacturer.
When requesting the manual, manufacturers mostly asks for the serial number on the equipment.
Often, manufacturers can check firmware version according to the serial number. And in this way also provide the specific manual for the firmware version.
When the manual is aquired, please send this manual to support@radimation.com
CheckList
This page should contain:
- Steps to request device driver
- Check if device driver is present in RadiMation. Also check if similar device is already supported.
- Requirements for the device driver request. E.g. only 1 EUT monitoring. Also Equipment must do EMC measurement. Device must be supported by manufacturer.
- Requirements for the Support team: Manual containing remote commands. And when the device is physically needed at DARE!!. We can place something that depending on the manual we can determine if we need the device.
- Switch matrix device drivers. Maby diagram of connections?
- In some cases it is not clear how the device is being used. We need examples of these cases where it is not clear.
And also the used communication type must be specified.
- Contain a download for the RadiMation installation guide?
- Further questions, contact Support@radimation.com
