The Tegam 91550-2 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tegam 91550-2:
The frequency range of the Tegam 91550-2 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Tegam 91550-2.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Tegam 91550-2 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
