Tekbox TBCCP1-2K70
The Tekbox TBCCP1-2K70 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tekbox TBCCP1-2K70:
The frequency range of the Tekbox TBCCP1-2K70 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Tekbox TBCCP1-2K70.
Be careful changing these settings as RadiMation® is no longer able to verify if the Tekbox TBCCP1-2K70 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
