Tekbox TPSCP1-3070
The Tekbox TPSCP1-3070 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tekbox TPSCP1-3070:
The frequency range of the Tekbox TPSCP1-3070 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Tekbox TPSCP1-3070.
Be careful changing these settings as RadiMation® is no longer able to verify if the Tekbox TPSCP1-3070 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
