Tektronix AFG 3021B
The Tektronix AFG 3021B device driver is a Signal Generator, Modulation Source which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tektronix AFG 3021B:
The frequency range of the Tektronix AFG 3021B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Tektronix AFG 3021B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Tektronix AFG 3021B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Tektronix AFG 3021B
- Google image search: Tektronix AFG 3021B
