Tektronix TDS 1000 Series
The Tektronix TDS 1000 Series device driver is a AD Converter which is supported by RadiMation®.
- Google search: Tektronix TDS 1000 Series
- Google image search: Tektronix TDS 1000 Series
How to configure the Tektronix TDS as an AD-convertor[edit]
- Press the "autoset"
- Enable the channel you want to use.
- Press "Measure"
- Press "Remove Measurement"
- Select "Remove All Measurements"
- press "Select Measurement"
- Select the type op measurement you want to make, for example Pk-Pk
- Start the measurement in RadiMation.
Note: this tutorial has been written with a DPO 4104.
