Teseq BHA 9118
The Teseq BHA 9118 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq BHA 9118:
The frequency range of the Teseq BHA 9118 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq BHA 9118.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq BHA 9118 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Teseq BHA 9118
- Google image search: Teseq BHA 9118
