Teseq CBA 1G-1200B
The Teseq CBA 1G-1200B device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq CBA 1G-1200B:
The frequency range of the Teseq CBA 1G-1200B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq CBA 1G-1200B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq CBA 1G-1200B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
