Teseq CBA 3G-050
The Teseq CBA 3G-050 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq CBA 3G-050:
The frequency range of the Teseq CBA 3G-050 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq CBA 3G-050.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq CBA 3G-050 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
