Teseq CBL 6111
The Teseq CBL 6111 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq CBL 6111:
The frequency range of the Teseq CBL 6111 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq CBL 6111.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq CBL 6111 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Teseq CBL 6111
- Google image search: Teseq CBL 6111
