Teseq DCP 0100A
The Teseq DCP 0100A device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq DCP 0100A:
The frequency range of the Teseq DCP 0100A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq DCP 0100A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq DCP 0100A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
