Teseq GTEM 250 SAE
The Teseq GTEM 250 SAE device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq GTEM 250 SAE:
The frequency range of the Teseq GTEM 250 SAE as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq GTEM 250 SAE.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq GTEM 250 SAE is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Teseq GTEM 250 SAE
- Google image search: Teseq GTEM 250 SAE
