Teseq HLA 6121
The Teseq HLA 6121 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq HLA 6121:
The frequency range of the Teseq HLA 6121 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq HLA 6121.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq HLA 6121 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
