Teseq NSG 4060
The Teseq NSG 4060 device driver is a Signal Generator, Amplifier, Coupler, Multimeter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq NSG 4060:
The frequency range of the Teseq NSG 4060 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq NSG 4060.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq NSG 4060 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Teseq NSG 4060
- Google image search: Teseq NSG 4060
