Teseq TEM Horn
The Teseq TEM Horn device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq TEM Horn:
The frequency range of the Teseq TEM Horn as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq TEM Horn.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq TEM Horn is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Teseq TEM Horn
- Google image search: Teseq TEM Horn
