Teseq VBA 6106
The Teseq VBA 6106 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq VBA 6106:
The frequency range of the Teseq VBA 6106 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Teseq VBA 6106.
Be careful changing these settings as RadiMation® is no longer able to verify if the Teseq VBA 6106 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Teseq VBA 6106
- Google image search: Teseq VBA 6106
