Test specific report generator inclusion codes
The report generator of RadiMation allows that test-specific templates of several tests are included in a main-template. See the Test specific report generator templates page for a more detailed description of this functionality. This page describes all the codes that are allowed to include test-specific templates. Depending on the code, the test-specific template of a certain set of tests will be include.
In the case that an inclusion code is specified in the report, while there are no tests executed for that type of test, no test-specific templates will be included at all.
||EUT|ALL TESTS|| ||EUT|ALL IMMUNITY TESTS|| ||EUT|ALL EMISSION TESTS|| ||EUT|ALL RADIATED TESTS|| ||EUT|ALL CONDUCTED TESTS|| ||EUT|ALL RADIATED IMMUNITY TESTS|| ||EUT|ALL CONDUCTED IMMUNITY TESTS|| ||EUT|ALL PULSED IMMUNITY TESTS|| ||EUT|ALL RADIATED EMISSION TESTS|| ||EUT|ALL CONDUCTED EMISSION TESTS|| ||EUT|ALL CALIBRATION TESTS|| ||EUT|ALL RI SUBSTITUTION TESTS|| ||EUT|ALL RI FIXED GENERATOR TESTS|| ||EUT|ALL RI FIXED FIELD TESTS|| ||EUT|ALL RI FIXED MAGNETIC FIELD TESTS|| ||EUT|ALL RI TRIPLATE TESTS|| ||EUT|ALL RI MINIMUM PERFORMANCE TESTS|| ||EUT|ALL RI MULTIBAND TESTS|| ||EUT|ALL CI SUBSTITUTION TESTS|| ||EUT|ALL CI FIXED GENERATOR TESTS|| ||EUT|ALL CI FIXED CURRENT TESTS|| ||EUT|ALL CI FIXED VOLTAGE TESTS|| ||EUT|ALL CI MINIMUM PERFORMANCE TESTS|| ||EUT|ALL CI MULTIBAND TESTS|| ||EUT|ALL PI ESD TESTS|| ||EUT|ALL PI EFT TESTS|| ||EUT|ALL PI SURGE TESTS|| ||EUT|ALL ESD TESTS|| ||EUT|ALL EFT TESTS|| ||EUT|ALL SURGE TESTS|| ||EUT|ALL RE ANECHOIC CHAMBER TESTS|| ||EUT|ALL RE FIXED HEIGHT TESTS|| ||EUT|ALL RE GTEM TESTS|| ||EUT|ALL RE MULTIBAND TESTS|| ||EUT|ALL CE LISN TESTS|| ||EUT|ALL CE ABSORBING CLAMP TESTS|| ||EUT|ALL CE CURRENT PROBE TESTS|| ||EUT|ALL CE AUTOMOTIVE LISN TESTS|| ||EUT|ALL CE MULTIBAND TESTS|| ||EUT|ALL RADICAL ANTENNA SCAN TESTS|| ||EUT|ALL RADICAL S PARAMETER TESTS|| ||EUT|ALL RADICAL ATTENUATION GAIN TESTS|| ||EUT|ALL RADICAL GAIN COMPRESSION TESTS|| ||EUT|ALL RADICAL HARMONICS TESTS|| ||EUT|ALL RADICAL FIELD SUBSTITUTION TESTS|| ||EUT|ALL RADICAL FIELD CALCULATION TESTS|| ||EUT|ALL EXTERNAL RESULTS TESTS|| ||EUT|ALL RE BURST TESTS|| ||EUT|ALL PI EFT MULTIBAND TESTS|| ||EUT|ALL PI SURGE MULTIBAND TESTS|| ||EUT|ALL PI MULTIBAND TESTS|| ||EUT|ALL RADICAL AMPLIFIER LINEARITY TESTS|| ||EUT|ALL PI VDI MULTIBAND TESTS|| ||EUT|ALL RV TESTS||
