Testlevel electrical field closed loop method
Test level: Electrical field closed loop method[edit]
A field to enter a description for the field test level method being configured. |
A dropdown menu to select the device used to measure the field, in this case, a Field Probe. |
A test level option where the field strength is kept constant at a specified level, in this case, 1 V/m. |
An option to set a range or variable field strength for testing. This option is disabled in the image. |
A field to set a tolerance level for field strength measurement in dB, which defines the acceptable variation range. In this case, it is set to 0.3 dB. |
A section to select from multiple probes (Probe 1 to Probe 8) for field measurement. Probe 1 and Probe 2 are selected in this image. |
