Testlevel electrical field substitution method
Test level: Electrical field substitution method[edit]
A field to enter a description for the calibrated field test level method being configured. |
A field to specify the calibration file path, which defines calibration settings for the test level. |
A test level option where the field strength is kept constant at a specified level, in this case, 1 V/m. |
An option to set a range or variable field strength for testing. This option is disabled in the image. |
An option to set a calibrated power level for testing, currently disabled. |
A power method that uses the signal generator level (Pin) as the reference for field strength measurement. |
A power method that uses the forward power (Pfwd) as the reference for field strength measurement. |
A power method that calculates net power by subtracting the previous power level (Prev) from the forward power (Pfwd). |
A field to set a tolerance level for field strength measurement in dB, which defines the acceptable variation range. In this case, it is set to 0.3 dB. |
