Testlevel magnetic field closed loop method
Test level: Magnetic field closed loop method[edit]
A field to enter a description for the magnetic field test level method being configured. |
A dropdown menu to select the device used to measure the magnetic field, in this case, a Multimeter and Resistor. |
A test level option where the magnetic field strength is kept constant at a specified level, in this case, 120.0 dBpT. |
An option to set a range or variable magnetic field strength for testing. This option is disabled in the image. |
A field to set a tolerance level for magnetic field measurement in dB, defining the acceptable variation range. In this case, it is set to 0.3 dB. |
