Testlevel magnetic field substitution method
Test level: Magnetic field substitution method[edit]
A field to enter a description for the calibrated magnetic field test level method being configured. |
A field to specify the calibration file path, which defines calibration settings for the magnetic field test level. |
A test level option where the magnetic field strength is kept constant at a specified level, in this case, 120.0 dBpT. |
An option to set a range or variable magnetic field strength for testing. This option is disabled in the image. |
A leveling method that uses the signal generator level (Pin) as the reference for magnetic field strength measurement. |
A leveling method that uses the forward power (Pfwd) as the reference for magnetic field strength measurement. |
A leveling method that calculates net power by subtracting the previous power level (Prev) from the forward power (Pfwd). |
A leveling method that utilizes a multimeter and resistor to measure magnetic field strength. |
A leveling method that uses a powermeter and current sensor to measure magnetic field strength. |
A leveling method that uses an oscilloscope and resistor for magnetic field strength measurement. |
A field to set a tolerance level for magnetic field measurement in dB, defining the acceptable variation range. In this case, it is set to 0.3 dB. |
