Thales ADOC
The Thales ADOC device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Thales ADOC:
The frequency range of the Thales ADOC as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Thales ADOC.
Be careful changing these settings as RadiMation® is no longer able to verify if the Thales ADOC is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Thales ADOC
- Google image search: Thales ADOC
