Error Report
Reporting a problem when an error is shown
- On the RadiMation® Error Window, press the Report button.
- The Error Report window will be shown.
- Specify your own contact details, so we know how to contact you for a solution. As seen in the screenshot, you also must check the I agree that my provided data is used to improve the products and services of Raditeq checkbox.
- Ensure that all the fields do contain the correct information. If not all fields are filled you can not send or save the file. When information is missing, a red circle with a cross is displayed. If you hover over it with your mouse it will inform you what is missing in the form.
- Once the report information is filled in the buttons change colour, the report can now be send to the RadiMation® support team in 2 ways:
- Send the report automatically using the Send button. A message will be shown that the error report is transmitted. You also will receive almost directly an e-mail from our ticket database with the ticket number that has been created for your error report.
- Save the report with the Save button, and send the file over email to radimation-support@raditeq.com
Manually reporting an issue
- Help
- Report
- Help
Reporting a RadiLog communication file only
- Open the RadiMation® logging tool (RadiLog) from the View menu in RadiMation®
- While the RadiLog tool is opened, reproduce the error.
- When the error has been logged, save the log file, by selecting 'File' and 'Save As...' from the menu.
- Send the .RadiLog file (zipped) to the RadiMation® support e-mail address radimation-support@raditeq.com
Sending larger files
